dayton gen.w/ 5h.p. b&s engine
Old 08-04-06, 04:06 PM
hitch's Avatar
Angry dayton gen.w/ 5h.p. b&s engine
anyone tell me how i can seperate the gen. from engine, armature connected to crankshaft but can't see how connection, wether by key or? it's an older model. 5w262. HELP!!!! THANX IN ADVANCE
Old 08-04-06, 08:22 PM
cheese's Avatar
The crankshaft is most likely tapered, and is held to the armature by a bolt from the other end of the armature.
Old 08-05-06, 07:23 AM
hitch's Avatar
crank shaft
thank you will go take a look,will let you know how it goes.thank you
hitch
Old 08-05-06, 07:51 AM
hitch's Avatar
hitch on gen.
could u tell me how is good way to seprate the 2 parts,i have the long bolt out now & soak w/ wd 40. again, i do thank u.
Old 08-05-06, 09:41 PM
cheese's Avatar
Usually a shock will separate the two. Use a block of wood or brass pin and a hammer to "shock" it near the joint while pulling back on the armature.
Old 08-07-06, 06:34 AM
hitch's Avatar
hitch
will do, thanx.
