Changing a Tecumseh flywheel
Old 08-12-06, 09:08 AM
Talking Changing a Tecumseh flywheel
I have a Tecumseh HM100 159409P 10 hp engine for a generator. I would like to put a electric starter on it but the flywheel is smooth. I believe the flywheel model # is 611090? What I want to know is, can I change the flywheel to accomodate the starter. There is a place on the side of the engine to put a starter. Also if I can change the flywheel could you include the #.
Thanks for your help.
Old 08-13-06, 08:42 PM
cheese's Avatar
You could replace the flywheel, add a starter, but then you'd also need to install a charging stator, or it will not keep the battery charged. You'll also need a battery, solenoid, and keyswitch. With this kind of money for parts (unless you're getting them used) and the amount of work required, it would probably be almost as economical to buy one with electric start on it already. I only mention this in case you haven't looked at the prices of these parts yet.
Old 08-14-06, 01:08 PM
This is for a back up generator and I can get the parts real cheap. I would like to know what kind of flywheel I would need.
Thanks
