Honda rear engine rider HT-R3009
Jack B.'s Avatar
AL
08-17-06, 08:01 PM   #1
I have a GXV270 engine off the rider. What I'm wanting to know is how does the starter bendix come off the shaft? The numbers on the side of the starter are: ND DB5DP 128000-2450. The reason I'm asking is, I believe the only way to get to put the new brush holders in is to completely disassemble the starter and start assembling it from the commutator end. Anyone have any better ideas?
cheese's Avatar
GA
08-17-06, 11:01 PM   #2
As I recall, there is a sleeve or collar at the end of the starter shaft. Drive it downwards towards the bendix gear to gain access to the "C" clip on the end of the shaft. Remove the "C" clip and the collar, spring, and bendix will slide off. Also, you can replace the brush holder assembly from the back end. It's a little tircky...best to have a helping hand. Use thin putty knives to hold the brushes down and slip the assembly in place while paying attention to the alignment of the brush plate, and hold in place while installing the rear cover. I did this once on a water cooled honda engine that required engine removal to gain access to the starter bolts, so I replaced the brush assembly with the starter still mounted to the engine.
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
Jack B.'s Avatar
AL
08-18-06, 05:35 AM   #3
Thanks Cheese for the infomation. I thought that the sleeve would 'push' down, I'll take a socket or something and try to drive it down.
Jack B.'s Avatar
AL
08-18-06, 08:07 PM   #4
Cheese - Your suggestion worked fine. But putting that brush holder on the commutator end was very tedious.
cheese's Avatar
GA
08-18-06, 11:19 PM   #5
Glad it worked! It is difficult to get everything in place all at the same time and then slip it together.
God bless!
