MTD yard machine stalls under load
Old 08-25-06, 02:18 PM
Hoping someone can point me in the right direction. I have a ?98 MTD yardmachine, 42 inch cut riding mower with a 14.5 HP syncho balanced OHV I/C quiet engine. Model # 287707, type 0224-01. Engine startes fine, idles and runs great. Pulls a 100 plus pound aerater up a 10% grade fine. The problem is when I engage the PTO (ie cutter blades). The engine occasionally backfires and wants to stall alot. Press in on the clutch-brake pedal and the engine well run fine, disengage the PTO and engine runs fine. Throttle control at full. THis happens in forward and reverse. The cutter blades spin free with belt off, changed the oil, fuel filter, fuel, air filter and spark plug. Cleaned around engine, removed the engine cover, fins are clear. THe question is what to do next. Is the possible problem fuel/fuel system (carb), or electrical . I am leaning towards carb. Any suggestions ???
Thanks in advance , Fixitup
Old 08-25-06, 04:32 PM
Azis
Sounds like it could be a safety switch cutting out. From what you describe it does not sound like an engine issue.
I would need the model and SN of the MTD to tell more, but I would start with the seat switch.
Old 08-30-06, 07:06 PM
Talking MTD yard machine, no longer stalls under load
Thanks Az, It was the seat switch. The right side of the seat hinge was bent, causing the switch to make and break contact.
Minor adjustments and the mower continues to run under load, no backfire or stalling.
Thanks : fixitup
Old 08-30-06, 07:56 PM
Azis
Glad it was a simple fix
