Broken lawnmower
1qaz's Avatar
08-27-06, 05:38 PM   #1
Broken lawnmower
Hi
I have a cheap lawnmower with a 2.5 hp briggs and stratton engine.
Ran over a hidden metal box and the engine stopped.
Now it seems like it is seized, at first I couldnt pull cord at all now pulling is 10x more difficult so I stopped trying.
Is the mower taost? Can I fix it?
Advice is appreciated.
cheese's Avatar
GA
08-27-06, 06:37 PM   #2
2.5hp engine? Sure it's not 3.5? Try turning it over with the spark plug out and see if it turns easily then.
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
v8driver's Avatar
08-27-06, 09:59 PM   #3
Have you taken a look at the blade and crank? (and yes, I believe you are talking about a 3.5, not 2.5 as they never went lower then 3hp on them)
geogrubb's Avatar
MO
08-28-06, 08:43 AM   #4
If after checking the blade and crankshaft for straightness(with the sparkplug out) you find they are ok you will then want to check the flywheel key it may have sheared and the engine is now out of time and trying to fire at the wrong time(it's the little key that aligns the flywheel to the crankshaft). Have a nice day. Geo
snoman's Avatar
CANADA
08-28-06, 02:59 PM   #5
1qaz
Well I'm not a gambling man but I'll put my money on a severely bent crank. There are times when it bends, that it'll chew up the bottom pan thus locking it up so you can't turn it over easily.
Best bet......start looking for another one.
snoman
hopkinsr2's Avatar
Non-US
08-28-06, 06:35 PM   #6
I'm with Geogrubb on this one. My bet is on the sheared flywheel key Roger
1qaz's Avatar
08-28-06, 08:36 PM   #7
It is a 4 HP engine.
I looked it over today and neither the shaft nor blade appear to be bent, I can't see any damage. I can turn the blade with diffculty.
I will take the plug out tomorrow and see if there is any difference.
A couple of times I managed to pull it to the point where I heard the engine turn, it sounded normal just much slower than normal, these times I was probably only getting it to turn about 10% of normal.
I assume checking the flywheel key requires dissassembly?
v8driver's Avatar
08-28-06, 10:23 PM   #8
I'm sure you were holding down the handle when you were checking the blade?
check both (the flywheel brake) and the flywheel key at the same time..... yes it means the shroud must come off, flywheel unbolted and removed to check the key.
