mower won't move
Old 08-30-06, 05:40 PM
mower won't move
I have a poulan / weedeater riding mower with a hydrogear transmission. Top pulley turns by belt, but mower does not move in F-N-R. Linkeage appears to be intact. Small lever with broken spring under pulley, to the left, is only obvious problem. But I can not see where the spring had attached. Any information would be greatly appreciated. Thank you,
ffej
Old 08-30-06, 07:05 PM
hopkinsr2's Avatar
It would probaly help the pros on this site if you included the model # of you're mower. I've worked on several Poulans, but some are different from others!!
Old 08-31-06, 05:29 PM
Mower won't move
My model # is 733-864,the serial # is HD145H42J. Poulan/weedeater. It is 1998 model.Thank you,ffej.
Old 09-01-06, 12:43 AM
cheese's Avatar
There should be 3 levers. One is the brake, one is the F/N/D lever, and one is the relief valve. If the relief valve is engaged, the pump will not drive the axles. This may be the lever you're describing with the broken spring?
Old 09-03-06, 05:34 PM
mower won't move
Thanks Cheese,the transmission had a tag with bar codes and numbers.It was made by Hydro-gear in Sullivan Il. I called them with the bar code numbers talked to Dan,who told me that lever in question was indeed a relief valve,which when ingaged would allow me to push the mower. Thanks again,ffej
