ryobi string trimmer starter rope broke
Old 08-31-06, 11:29 AM
Question ryobi string trimmer starter rope broke
I have a 725r ryobi string trimmer that has a broken pull cord
and I can not figure out how to get the clutch drum assembly
off. Can anyone tell me how to accomplish this task?
Old 08-31-06, 09:37 PM
repair_guy's Avatar
New Member
After you take the starter cover lose from the clutch cover and shaft the first thing you'll see will be the clutch drum with a spring on it.Make sure NOT to loose this spring.But the part of the drum (where the drive shaft goes) has a torx headed bolt that has to come out.This is screwed into the crankshaft...so take the spark plug out and insert 1/2" rubber tubeing into the hole to stop the piston from moving.After this comes off unscrew the clutch CCW.Then the recoil cover is ready to come off.
Last edited by DIYaddict; 09-01-06 at 06:09 AM. Reason: removed quote as it's unnecessary to quote the entire post that's directly above yours
Old 09-01-06, 05:08 PM
Smile
I use starter a piece of starter rope, to put down the spark plug hole to hold the crankshaft.
Jerry
Old 09-01-06, 05:53 PM
repair_guy's Avatar
New Member
I thought that was a good idea too,In fact I used pull rope to stop the piston and crank from moving for years myself.Until one day a piece of rope got hung between the piston and cylinder.Ever since then I have been useing plastic fuel line,about 7/16" OD that is big enough it wont get hung and it still wont scratch the piston/ctlinder wall.
Just a bit of (maybe)??? useful advice
Old 09-03-06, 07:15 AM
Smile
Thanks repairguy,I never thought about that,I'll try that next time.
Jerry
Old 09-09-06, 08:32 PM
Question solved one problem now I have another bigger one.
Thanks for the helpful tips.I tried the rubber hose and could not get it to hold,so I tried the cord and was succesful in gettin it apart. I replaced the starter cord and fired it up. It ran great for a few minutes and the the engine locked up.I guess I will have to take it apart and see what happen.
Thanks again for the help.
