Eager Beaver 282 - Oil / Gas Mix?
Old 09-04-06, 02:30 PM
Anyone know the oil and gas mixture ratio for the Eager Beaver 282 weed eater?
Thanks
Old 09-04-06, 08:08 PM
hopkinsr2's Avatar
I'm sure you're safe if you run it @ 40:1 I'm sure the pros will be here soon to verify this
Old 09-05-06, 01:44 PM
yep...40:1 is the mixture for all generic two stroke engines installed on blowers/edgers and similar devices.
When you store any two stroke motor away during winter be sure to drain all the fuel, start the engine and let it run unitl it eats up all the fumes. These fules separate over time and create small amounts of water in the carb and the motor may not run at all afterwards or run very badly.
Cheers,
marclar
Old 09-07-06, 06:58 AM
Thanks
Here is a PDF version of the Manual you trimmer
http://www.sbsager.com/282/
