Hydro slipping out of gear & whinning uphill
squeegee's Avatar
09-05-06, 09:55 AM   #1
Hello Cheese and friends,
Just purchased a 96' used Yard-Man 42' 17.5 B&S with a hydrostatic drive. This is my first hydro-drive tractor. After i started mowing in MY yard with HILLS, i noticed that the Hydro drive would slowly ease out of the full forward postion, when i would go up hill or make sharp turns. I also noticed that "Neutral" was a very hard to find (your either creeping in either direction, unless you work the lever a few times) I messed with it, reset the neutral sweet spot and it is still very sensitve, and I tightened a spring (tension) on the scissor mechanicals on the lever/hydro adjustment and it helped a little.
Now when i mow I can make it up the hill without my hand on the lever, but the lever does start to ease back toward the neutral postion again, when i go to push it forward to FULL it whines pretty louding, like i am stalling the hydro. Sooo ...
1. Is hyrdo fluid low or old, need changing? I think this one has a sealed unit though.
2. Is neutral that sensitive on most hydros? Or is this related to my other MAJOR concern?
Being my first Hydro, I really need to know if i am looking at problems and how to fix them.
Thanks in advance,
Squeegee
cheese's Avatar
GA
09-05-06, 01:50 PM   #2
Hello squeegee!
Some hydros have a groan/whine, especially when they first take off from a stop. This can be normal if it's not excessive. It sounds like probably your main concern is having it creep out of position. I think tightening the nut at the tranny shifter area will help that.
Take a look at the top of the tranny. If it's covered with grass/dirt, it would be a good idea to clean it off. There should be cooling fins under the input pulley that need to be clean to keep the unit from overheating.
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
squeegee's Avatar
09-07-06, 11:22 AM   #3
checked the fan, the blades everythings looks clean and operational. The spring is all the way in (tight) but still ceeps back? Any other tips? Maybe a slipping belt?
