carb leaks fuel
Old 09-06-06, 02:34 PM
Cool carb leaks fuel
after shuting off my trimmer gas pours out of the carb were the choke covers or uncovers the hole
Old 09-06-06, 06:21 PM
Try this, Remove the gas cap when you shut it off, it has pressure built up in the tank, that is how some of them work. You have a valve in the carb that is not working properly, you are close to a carb rebuild, until it really gets bad just loosen the gas cap when you are finished using it. Have a nice day. Geo
Old 09-07-06, 03:06 AM
puey61's Avatar
The cap-loosening trick is just a bandaid, you need to rebuild the carburetor.
Old 09-07-06, 11:33 AM
gas cap trick didnt work
so i had the carb apart very simple but not like car or motorcycles nothing seemed to be damaged the diaph isint cracked maybe a little wrinked hard to tell made out of paper or gasket material. whats the averge cost of rebuild kit. is it worth doing or just get a new trimmer. thanks for the help guys!
