Craftsman 5hp snowblower w/tecumseh engine
Old 09-16-06, 12:18 PM
I just recently purchased this snowblower,model-536 886440, got it home it had old gas in it, emptied it out, sprayed the carb w/cleaner, replaced the plug.
Now for the problem, it will start after a few pulls, but won't stay running for any more than a minute then it kills. Try to restart it and it pops...like it's backfiring. The muffler seems to be extremely hot after running for only a short time.
I am a novice at small engines so I have no idea about adjustments, etc.
No owners manual came with it...so I am totally lost.
Can anyone help??
Thank You in Advance,
Tom
Old 09-16-06, 07:28 PM
Sounds to me like the carb needs a disassembly and thorough cleaning. From what you describe it is running too lean. Before removing carb make sure there is good flow from tank to carb. the problem may be there instead.
Mike
Old 09-20-06, 06:46 AM
5HP Tecumseh
Thanks Mike,
That was my next step, I got advice to remove the bowl bolt and check the holes in that when I got it off I noticed the bowl was pretty varnished, cleaned the bowl and the bolt "pin" holes, reassembled and still the same thing. So this weekend I am going to take it apart and do a thorough cleaning. Do you have any advice as to what product to clean it with, I have heard SeaFoam works good....or an tips on disassembly?
Is there a fuel filter or air filter that might be plugged also?
Thank You,
Tom
Old 09-20-06, 07:05 AM
Azis
Might be a good idea to check the flywheel key. Sometimes they can shear just enuff to change the timing and cause symptoms you mention.
NAPA carries a good bath type carb cleaner.
