spratt pressure cleaner w/honda engine
Old 09-19-06, 05:59 PM
Spratt 1500 psi pressure washer with Honda gx140 5 horse engine.
Problem: Engine starts right up and runs fine until I engage the pressure cleaner. After pressure cleaning for a few minutes the engine starts to stumble and then stalls. Will restart but continues to stumble and stall when the engine is under load. There is a rod that moves back and forth (think its the govenor rod) when the engine is under load. Any ideas. Thanks in advance for your help.
Old 09-20-06, 03:05 AM
puey61's Avatar
The trouble you have, most likely, is pump related and not engine related. And, most likely, is the unloader valve.
Old 09-20-06, 06:51 AM
Azis
If the symptoms appear while pressure washing, IE:with the trigger pulled, its prolly not the unloader valve. Check the hoses fittings gun and wand for damage or obstruction.
