tecumseh oil leak
Old 09-26-06, 05:28 PM
tecumseh oil leak
i have a tecumseh motor on a craftsman mower that blows gas and or oil out the muffler. i have found that there is oil being blown thru a hose into the air filter compartment, thru the carb, cumbustion chamber and out the muffler as a gas/oil mixture. i have read of the possibility that a breather hole is clogged and not allowing oil to return to crankcase. is this true and where do i find the clogged hole. any suggestions?
Old 09-26-06, 11:41 PM
cheese's Avatar
Chances are, if you'll look at the oil level, it's too full and/or thinned with gas. Smell the oil for a gassy smell. If so, you need to fix the leak in the carb.
Old 10-06-06, 03:15 AM
puey61's Avatar
Tom, did you solve your trouble. In other words, did you recondition the carburetor?
Old 10-14-06, 02:05 PM
yes thanks for the reply. turned out to have a small crack in the float. runs pretty well now.
Old 10-15-06, 11:28 PM
cheese's Avatar
Great! Glad you got it fixed and thanks for the update. That gas-thinned oil finds a way out of an engine when regular oil stays put.
Trackbacks are On
Pingbacks are On
Refbacks are On
