Need for speed
Old 09-30-06, 09:52 AM
Need for speed
I have a mtd riding mower 13am675go62. Every time I adjust the speed it seems to be too slow. I'm going step by step by the manual. It has always done this from the first time I changed the belt. Can I just shorten or lengthen the speed link?
Old 10-02-06, 12:12 AM
cheese's Avatar
Received 22 Votes on 19 Posts
Did you replace both motion drive belts, or just one? If not both, then tha's probably the problem. The varidrive system doesn't work right with one worn belt and one new.
Old 10-02-06, 04:02 AM
puey61's Avatar
Also, be sure the two needle bearings in the vari-drive stack pulley are not frozen and that the center sheave has freedom of movement up and down the entire assembly.
