Riding lawnmower won't start.
kiki1971's Avatar
10-03-06, 03:15 PM   #1
I hope i'm putting this in the right place. The key 'turns' the engine over when I try to start our lawnmower, but the thing that 'spins' won't move and just makes a whirring sort of noise. What could this be?
Thanks in advance!
Pilot Dane's Avatar
NC
10-03-06, 04:16 PM   #2
Make sure you battery is fully charged. If it's charged and you are still getting the whirring noise you may have a bad starter or stripped gear.
hopkinsr2's Avatar
Non-US
10-03-06, 06:43 PM   #3
If it's a Briggs (post some engine numbers) single, I'll bet the plastic ring gear is stripped. Pull the fan shroud ( not a big job) & look @ the teeth of the gear around the flywheel. Are the wore off near the starter?? If so, there is a repair kit for this. Let us know what engine you have as this may not be the answer. Good Luck, Roger.
