Stihl Chainsaw
mchristo63's Avatar
10-04-06, 07:56 AM   #1
Stihl Chainsaw
I am in the process of rebuilding my Stihl chainsaw carb. I am having troubles identifying this Stihl model. The only sticker on the saw is 311Y. Searching for parts for a 311Y is not returning good hits. Is this a real model number? Is there another way to identify this chainsaw model?
Thanks
puey61's Avatar
NY
10-05-06, 06:15 AM   #2
Should be on a sticker on the visible exterior of the saw such as 011, 024, 045, etc. Or, if newer, such as MS160, MS390, MS660, etc. However, with a carburetor, it isn't necessary to know the saw model. On the carb you will see a model and serial number of the carb itself. Knowing the brand carb (commonly either Walbro, Tillotson or Zama) and the aforementioned numbers, you can go to most saw shops and get the carb manufacturers rebuild kit and not have to worry about the make of saw it's on.
Azis's Avatar
10-05-06, 07:30 AM   #3
Azis
Posted By: puey61 Knowing the brand carb (commonly either Walbro, Tillotson or Zama) and the aforementioned numbers, you can go to most saw shops and get the carb manufacturers rebuild kit and not have to worry about the make of saw it's on.
I have not found this to be so with most Stihl and some other brands. Carbs on most Stihl saws I have seen are stamped with the name "Stihl" even tho made by Walbro, are only available to Stihl dealers. Most gaskets from other common kits however are the same. It may require taking the old carb and parts to a shop to match up from another kit if not a Stihl dealer.
LinkBacks (?)
LinkBack to this Thread: https://www.doityourself.com/forum/outdoor-gasoline-electric-powered-equipment-small-engines/279941-stihl-chainsaw.html
Posted By For Type Date
SOLVED: How do you remove the handle of a Stihl 017 - Fixya This thread Refback 09-29-17 02:12 PM
SOLVED: Need a diagram of fuel line system for a 311y - Fixya This thread Refback 08-27-17 08:16 AM
Fuel line diagram for stihl 009l chainsaw - Fixya This thread Refback 08-24-17 10:55 PM
