Kohler w/Walbro Carb leaking fuel
Old 10-05-06, 01:44 PM
Simplicity, Kohler 14hp CV14S, with Walbro LMK carb
Leaking fuel after shutdown. Bought repair kit, replaced needle valve, float is OK, fuel tank is not pressurizing, blew out fuel lines and carb with compressed air to remove any debris, new fuel filter.
Kohler tech support says to use a valve lapping compound to make sure no pitting has occured in brass seat. Sometimes it works, maybe not and have to buy new carb.
I have tried everything and still problem exists. Am I going to have to buy a new carb? Can valve seat be replaced?
Thanks
Old 10-05-06, 02:47 PM
puey61's Avatar
Be sure the bowl vent is unobstructed. If this is OK and the carburetor does not have a replacable inlet seat then good luck with the grinding compound, I've never had this work favorably. But, it's always worth a try since the only option left is to replace the carb. Post back with the engines' specification number.
Old 10-05-06, 03:17 PM
Engine spec # is 14107
Where is the bowl vent?
Old 10-06-06, 12:01 AM
cheese's Avatar
I think the vent is under a welch plug and vents to the throat of the carb on this. The vent could be an issue, but not as likely as the seat. I have had success using polishing compound and a Q-tip. I dip the Q-tip in turtle wax polishing compound (in the red container similar to the paste wax in the green tub), put the Q-tip in a drill, and use it to polish the seat area...with light pressure to get the contact area of the seat nice and smooth. Don't do too much (it can distort the shape of the seat with too much polishing). This generally works for me. Valve compound is too abrasive.
Old 10-06-06, 03:08 AM
puey61's Avatar
Good tip, another one for the upstairs file. Thanks Cheese. However, Bama, my records indicate that this carburetor has a replaceable inlet seat. It's black in color and may be unnoticeable in the cavity. Is the tip of your inlet needle steel or is it a rubber-like material? See if you can dig your fingernail into it -indicating rubber - or not. I believe it should be steel and therefore will have a replaceable seat. The Kohler kit part number is 12 757 03-S. and includes such items.
Old 10-06-06, 03:28 AM
The needle does have the rubber tip. The valve seat appears to be all brass and the kohler rep said the same thing. Looks like I'm going to be out $100 + for a new carb.
Old 10-06-06, 02:41 PM
puey61's Avatar
Try Cheese's Q-tip trick first though.
Old 10-07-06, 03:27 AM
Thanks for the help, I'll give it a try.
