tecumseh small tiller
clyfe's Avatar
10-12-06, 02:13 AM   #1
engine won't start unless I use starting fluid, and then stops when starting fluid is gone.
jarhead's Avatar
10-12-06, 05:17 AM   #2
you got spark so its a fuel delivery problem. best bet the carb needs a good cleaning and fresh gas.if that doesnt do it post back with engine model and make and the pros' will get you going for sure.
v8driver's Avatar
10-12-06, 06:40 AM   #3
I'd also agree..... carb problem, and or no fuel getting to the carb..., easiest thing to check is if gas is getting to the carb.
Take the fuel line off at the carb (while pinching it) and let it go real quick in a can and watch for a good flow....., little trickle is no good.
If thats good, then onto the carb.. I'd go ahead and get a carb rebuild kit and take the carb off and apart and soak it in carb cleaner for a couple hours, and blow all the holes out with air (can do that with carb cleaner as a little extra insurance along with the air)
cheese's Avatar
GA
10-12-06, 12:13 PM   #4
A little info might help...is this a little 2-stroke tiller, or larger? Engine size and model?
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
