Honda ex650 generator only runs on full choke
mrfdoit's Avatar
10-18-06, 11:47 PM   #1
Even after it warms up my honda ex650 portable generator cuts off if I turn the switch to disengage the choke. Will only run with it on full choke.
The linkage seems to be working properly, is there a carb adjustment that can be made that may remedy the problem. Any ideas?
thanks, mike
cheese's Avatar
GA
10-19-06, 12:59 AM   #2
That generally means you have a restriction in the carb. Probably rust or junk in it. You'll need to remove and clean out the carburetor.
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
mrfdoit's Avatar
10-19-06, 11:25 AM   #3
Thanks
Carb restriction sounds right. It has been sitting unused for a couple of years. Thanks much.
Mike
puey61's Avatar
NY
10-20-06, 03:12 AM   #4
By the way, you will likely not find a single fuel adjusting screw on this engine as all Honda engines that I've ever serviced are fixed jet carburetors. The only screw for any adjustment will be the idle RPM screw.
