snapper rear end diagram
Old 10-31-06, 05:57 AM
Hi,anyone know where I can download a diagram or exploded view of a early model snapper rider,about 1978 or so? I'm trying
to rebuild/restore this old thing and forgot exactly where the
spacer on the axle goes(the one with the set screw) I thought
it went on after the side plate,then the dust cover went over that..and although I wrote it down as I dismantled it,it doesn't
seem right to me...any ideas? thank's
Old 10-31-06, 10:04 AM
30yearTech's Avatar
http://www.snapper.com/#
go to the above site, click on publications, select your model from the list on the drop down menu, and select the type of manual you want "parts" and press the search button, you can then download a pdf that shows a breakdown of the rider. A 3081w shows to be a 1978 model.
Old 10-31-06, 10:56 PM
cheese's Avatar
It does go on after the side plate and before the dust cover on the the left side of the mower. It's not a spacer...it's a lock ring for the inner bearing race on the bearing for the axle. The side with the recess goes toward the bearing and over the flange on the bearing. Then, with a punch in the hole on the lock ring, tap it around until it is tight on the flange on the inner bearing race, and then tighten the allen head set screw. This was typically on newer models than 1978, but it's not uncommon to see them installed on the older models, since the original bushing that they came with often wore out after 20 years of mowing grass.
Old 11-01-06, 04:20 AM
Thank's!
Exactally what I needed! the snapper downloads are great,but
offer so many, and all the number's being gone or painted over
after all these years I had no idea what series it was,so I thought i could go from the engine year(a 78) but it could have
been replaced...but I think I've got a grasp on it now,CHEESE your explanation was dead on! thank's
Old 11-01-06, 11:58 PM
cheese's Avatar
Great! Glad I could help!
Old 11-03-06, 01:02 AM
Bigwind's Avatar
Cheese must have "Total Recall"? Amazing!
Old 11-06-06, 01:28 AM
cheese's Avatar
Ha! No... It's just that over the past 2 years, I've had a rash of snappers needeing repairs in the drive system...mostly axle boot replacements...but it's a process I can do with my eyes closed by now, and all the parts are very familiar to me.
