5hp Briggs Throttle
Old 11-10-06, 07:14 AM
5hp Briggs Throttle
Briggs 5hp. Model: 135202 Type:1171E1 Code: 971114YA
http://www.sbsager.com/Bracket.jpg
This engine was given to me with a problem. Below the carb is the bracket that braces the carb/fuel tank. In this bracket is a plastic slider that you would connect a throttle link to for controlling the engine speed. This slider has grooves that engage teeth on the bracket but there is nothing connecting this to the carb. I guess my real question is how does this work ??
See attached picture for carb suppott bracket.
Old 11-10-06, 08:23 AM
30yearTech's Avatar
A small governor spring attaches to the lever on the back side of this bracket. The spring then attaches to the governor arm that should have a linkage that goes upwards and attaches to a pivot arm, the pivot arm attaches to the carburetor with another linkage rod.
Look behind this plate and see if there is a small spring hanging down from a small arm that is attached to the side of the engine block behind this bracket assembly. They sometimes come off of the lever on the throttle plate assembly.
Old 11-10-06, 10:06 AM
I do have all the correct linkages from the Gov arm to the carb. The engine runs, idles and revs by hand perfect. I guess I just need a spring to connect the level to the govenor arm ?? Any part numbers for this ??
Old 11-10-06, 10:20 AM
30yearTech's Avatar
Double check the type number off of your engine, I have been unable to locate a parts list for a model and type engine you listed.
Old 11-10-06, 11:25 AM
Sorry I mistyped the type
correct numbers:
Model: 135202
Type: 1171E1
Code: 971114YA
Old 11-10-06, 02:22 PM
30yearTech's Avatar
The governor spring shows to be a Briggs and Stratton 691816 Spring-Governor ((Black))
