11-11-06, 03:19 PM
Ryobi trimmer 725R 31CC 17"
I just picked up a Ryobi trimmer 725R 31CC 17" from the pawn shop in town, but it didnt have any fuel lines attached... I have line to use, and inside the tank there is a fuel filter. Do both lines that leave the gas tank both then up connecting to the carb? There is two connections on the carb, one on top, and one under it. Do the two lines that are connected to the tank both need fuel filters? Thanks for your help,
Tommy
UPDATE: I have connected both fuel lines from the gas tank directly to the carb, bypassing the primer. The engine started and ran fine, except it is leaking fuel from the intake on the carb. I killed the engine, and picked it up, and fuel just dumped out... Did the primer act as a fuel shutoff switch also? Thanks
Tommy
GA
