11-13-06, 10:30 AM
craftsman blower
Got This Blower 32cc Mod#358.797921, Wasnt Running When I Got It, Tore It Down And Cleaned The Carb. Got It Running But Wont Stay Running, Also If You Try And Throttel It, It Dies Out. I Have Adjusted The Carb Settings In And Out But Cant Find A Medium To Keep It From Stalling.everything Looked Good In The Carb, The Diaphram And Needle.new Gas. Need Some Help With This , Thanks For Any Suggestions.
11-13-06, 10:43 AM
Azis
If you are confident about the carb, check the exhaust/muffler for blockage or spark arrestor. Also inspect the cylinder and piston.
AL
11-13-06, 10:46 AM
jarhead,try taking the muffler off and seeing if the exhoust ports or muffler is partly stoped up.This will cause an engine to go dead sometimes.And then adjust the carb.if needed.
AL
11-13-06, 11:27 AM
Another cause.......often over looked is a missing or un-connected fuel filter (in the fuel tank).
