enginer on onan generator won't start
Old 11-14-06, 06:00 AM
I thought I had a problem relating to the start switch and got advice to replace the voltage regulator - did that and now it seems that either that was not the probem or I have multiple problems.
With the new voltage regulator, I now get combustion when I push the start swtich, but enginee won't actually start - just pops.
The automatic choke/throttle seems strange - does not seem to stay in correct postion to start, but might be that I do not know what to look for.
Also -I noticed one drop of fuel coming from bottom of carb bowl - drop seemed orange, making me think I may have a gummed up carb (previous owner had not run it for a long time). I tried spraying in some starter fluid, but that did not change anyhting. Air filter and air filter housing seem to be missing.
Any suggestions? If I try to remove carb bowl to check, any reassembly problems I might encounter?
thanks
Dale
Old 11-14-06, 10:14 PM
cheese's Avatar
Yes, you'll probably have to take the carb apart and clean it...you'll also probably need a new needle (and seat if it has a rubber seat) since you mentioned it was dripping. The no start could be the old gas, it could be flooded, a spark plug problem, low compression, stuck valve, etc... You'll want to make sure you have good compression and spark.
Trackbacks are On
Pingbacks are On
Refbacks are On
