20 hp briggs governor replacment
Old 12-06-06, 08:26 AM
Briggs model 407700 vtwin 20hp engine. It was over reving and took it apart and the governor assembly was broke. I ordered a new governor gear and im not exactly sure how the pin, governor, and cap fit it properly. Has anyone changed this part and whats the proper placement of the part.
Thanks Josh
Old 12-06-06, 11:42 PM
cheese's Avatar
You can view an illustrated parts list here: http://shop.briggsandstratton.com/BShopProductListingPage.asp?rsvp=0&PARENTID=0&SessionID=43C7B3A0-6A44-4EB2-B2CC-23B437198A68&MECID=100&CATALOGID=56B2B9A7-283C-11D4-8886-00B0D0203414
Copy and past into your browser. Enter your engine numbers and view a breakdown of your engine to see how it is assembled. Much easier than trying to convey the procedure in text.
Old 12-07-06, 06:44 AM
Ive already seen the parts brakdown. It doesnt help. It just shows the parts. It doesnt show assembly of the governor. Has anyone replaced a governor that could help me put it back togeter.
Thanks Josh
Old 12-10-06, 03:52 PM
There has been 56 people looking at this post someone must have replaced a govoner. I need the room in the garage please someone help
Josh
Old 12-11-06, 10:19 PM
cheese's Avatar
I've replaced lots of governors, but I can't say I've ever even taken one out of that engine. Governor replacement isn't really that common of a job, but surely someone has done it on this engine. I'll look at a microfiche and see what I can tell about it.
Old 12-12-06, 05:44 AM
Azis
I can't get the IPL to come up without a type # for the engine, so while I could surely provide plenty of advice none would prolly pertain to your situation :P
Old 12-12-06, 04:10 PM
repair_guy's Avatar
New Member
The gang is right joshhoward,407700 is the starting of the model serise of your engine.Which might have as many as 20 to 30 or more differant engines in it.If you get one little thang wrong,you risk chances of blowing your $1200.00-$1800.00 engine from kingdom come.And I know that you don't want that to happen.But with both the model and type numbers we can not only tell you how to put the goverenor gear in correctly,but also how to saftly check it to see if it's set right.
Old 12-13-06, 03:10 AM
puey61's Avatar
I've never had to replace such on this series engine in my 26-years in the business but the order of parts will be as follows: Thrust washer then governor gear then retainer clip then governor cup. I assume that the cup snaps into place or is merely held in place by the flyweights of the gear. Any adjustments will be made externally by way of the governor shaft and arm. You loosen the governor arm, rotate this counter-clockwise and then rotate the governor shaft clockwise then tighten the arm clamp back down.
