49cc Mini Ninja not starting
Old 12-08-06, 07:24 PM
I have a 49cc mini ninja which ran perfect. The gas cable broke so i had to remove the carbureator air cleaner to replace it. I replaced it with and new one and accidentally started the bike with the air cleaner off and it ran for about 2 seconds then died. Took it to a marine repair specialist to have the carbureator cleaned. That was done. fuel air and spark are present. But won't run. Help.
Old 12-09-06, 12:38 AM
cheese's Avatar
Is this one of the chinese pocket rockets? If so, good luck. None of the shops in my area will work on them. Does it have compression? Is the plug wet?
Old 12-13-06, 06:14 AM
puey61's Avatar
Same story here, in upstate NY. No one wants to work on these machines. It sounds like you lost spark. You'll need to diagnose such and hope you can find parts.
