electric starter
djt's Avatar
PA
01-09-07, 07:39 AM   #1
electric starter
My electric starter from my craftsman snowthrower just whines when i try to start it.I would like to know if i could replace some parts without buying the whle starter.It is a tecumseh product starter # 37000.It has a black cap on the front of it and i was wondering how to get it off.
Thank you
Square Head's Avatar
CANADA
01-09-07, 11:51 AM   #2
Starter.
It sounds like it's spinning but not engaging the flywheel.
You might be able to buy a rebuild kit for it. Not sure.
It just bolts up to the side of the motor.
I know on my craftsman, I had to take the gas tank off to get at it.
cheese's Avatar
GA
01-09-07, 07:25 PM   #3
The starter can probably be fixed. Check to see if the bendix is engaging with the flywheel. If not, you can remove the bendix and clean it and the starter shaft. If it's engaging the flywheel, but the bendix is slipping, you can replace the bendix.
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
djt's Avatar
PA
01-10-07, 05:55 AM   #4
electric starter
the bendix is not engaging the starter.how do i go about taking the bendix off of the starter.when i try to start it all it does whine and nothing.
cheese's Avatar
GA
01-10-07, 10:39 PM   #5
There should be a black plastic cap on top of the bendix. Remove it, then tap the ring at the end downward and remove the clip that is on the shaft, and the entire bendix assembly will slide off. I'm still not sure if the bendix is engaging the flywheel or not???
God bless!
crom60's Avatar
01-11-07, 02:53 PM   #6
Also check to make sure the mounting bracket has not broke, I just had the same problem on mine the bracket had broke free a bit. So the flywheel and the starter did not mesh up.
Crom
djt's Avatar
PA
01-12-07, 07:54 AM   #7
electric starter
Cheese how do get the black cap off?
puey61's Avatar
NY
01-12-07, 02:22 PM   #8
You'll have to ruin it to remove it. Pliers and a twist and pull motion.
djt's Avatar
PA
01-17-07, 06:22 AM   #9
electric starter
puey61
when i get the black cap off can i get another one to replace it or just leave it as is.
puey61's Avatar
NY
01-17-07, 12:12 PM   #10
The dust cap is available seperately and is Tecumseh part number 37051. If, on the other hand you need to replace the gear you may as well get the gear kit, part number 37052 and this includes the dust cap.
djt's Avatar
PA
02-07-07, 10:24 AM   #11
djt
I gotthe gear kit on but the dust cap will not do on.is there a special way the dust goes on.thank you.
puey61's Avatar
NY
02-07-07, 04:57 PM   #12
Tap it on with a rubber mallet. Or, if your hands have decent strength, then just apply good pressure with the palm of your hand and it will snap into place.
