Lawn tractor starter
Old 01-21-07, 07:00 PM
My Murray lawn tractor has been clicking when starting for about a week. Then just clicking, now nothing. Do these things have starters? Model 425001X8, B&S 17.5 HP OHV engine.
Old 01-21-07, 07:54 PM
Yes they do have starters. Click and a week later no click. Sure sounds like a dead battery. Put a volt meter across the battery terminals and see what it reads. Then, while the meter is still attached, turn on the key and try to start it. If the voltage dives, the battery is bad.
Old 01-22-07, 04:36 AM
Brand new battery. While we're on the topic, it's tended to run batteries down fast. My solution has been to park it with the blades engaged because - my thinking was that something was draining the battery. Anyway, I'll check the battery.
Old 01-22-07, 04:38 AM
I was just reading over my original post - when I said " now nothing", I meant it won't start!
Old 01-22-07, 06:11 AM
Azis
The starter will not operate when the blades are engaged.
Old 01-23-07, 12:00 AM
cheese's Avatar
It does sound like a dead battery. If not, then the solenoid could be the problem.
Old 01-23-07, 10:04 AM
Alternator
After you disengage the blade and re-try to start, if you get it going, measure the battery voltage. A normal reading should be 13.5V or higher, indicating the engine's alternator is charging the battery as it should. If it's anything below 12.5V, then either the alternator's stator or rectifier is bad.
Your engine has an alternator in the form if a series of stator coils situated inside the engine's flywheel. As the flywheel spins, a series of magnets along its inside edge pass over the coils inducing an AC voltage (that varies with engine speed) at the leads coming out of the stator, which is then rectified to a pulsing DC for recharging the starter battery and powering lights, etc. This works just like the alternator in your car, but a little less elegant, as it is essentially unregulated.
