No Spark
Old 01-26-07, 04:15 PM
michaeljp86's Avatar
Angry No Spark
Its the same 12.5 2 cyl briggs causing me trouble again. I got it to turn over good but it has no spark. I disconnected the little black wire that goes to the key switch so I know thats not shorted out. Does anyone have any idea whats wrong with it?
Old 01-26-07, 05:33 PM
repair_guy's Avatar
New Member
Often times rust forms on the magnet of the flywheel and or the coil.Clean with sandpaper and re-gap the coil.If this doesn't work with ground wire disconnected,the eletronic ignition is bad and needs to be replaced.
These,most of the time goes out without warning too.
Old 01-26-07, 10:49 PM
cheese's Avatar
Unplug the black wire from the coil itself, if that's not where it's disconnected from. If still no spark, and you have a good plug and the proper air gap, then the coil is bad.
Old 01-27-07, 09:00 AM
This morning I took the coil off and claened it up and the same with the magnent on the flywheel. I also left the black wire disconnected when I put it back on. I cranked it over and guess what, still no spark. Is the eletronic ignition part of the coil and thats what went bad? I think as soon as this pain in the but gets running it going up forsale.
Old 01-27-07, 09:28 AM
Azis
Coils go bad, its not at all uncommon whether with electronic module or not. As your witness too, they survive in a rather harsh environment.
Old 01-27-07, 01:41 PM
I have good news, I pulled out the spark plugs so it would spin faster and it had spark. It was spinning quick with the plugs in so I dont know why it didnt have spark before. I got another battery so it spins quick so Im not sure if its spining fastenough now or not, it should be. It didnt fire with starting fluid though.
Old 01-27-07, 07:34 PM
repair_guy's Avatar
New Member
Might B only the plugs then.I've seen that too,cracked and leting the spark jump to ground B 4 it ever reaches the electrode.
Old 01-27-07, 08:34 PM
Sounds like you may have a timing problem. Check the flywheel key to see it hasn't partially sheared. Have a nice day. Geo
