3hp Edgar
3hp Edgar
Customer brought me a edgar model #80202 type 2288 01 code 90112603 I check for spark,it has a good spark,check the compression with a gauge it was 65#the problem I have with it that it spits gas back through the carb,tried using starting fluid still won't start,could it be the intake valve sticking or a partly sheared flywheel key,or just a dirty carb,sprayed carb cleaner in the carb,no help.
Thanks
Jerry
Thanks
Jerry
