Craftsman ll backfiring
mntbkr's Avatar
02-22-07, 09:52 AM   #1
Have a Craftsman ll 5 HP electronic ignition rototiller (model 247.298611)? that RAN good but had a periodic squealing noise coming from the recoil starter. I replaced both the starter pulley and starter clutch but now tiller will not start. It backfires into the carb and and feels like its about to break my arm off. Did I miss some setting when I screwed the clutch starter onto the crank? Thanks much. Mtnbkr
gardener321's Avatar
SC
02-22-07, 10:44 AM   #2
Sounds like the flywheel key is sheared. Remove blower housing and remove nut from magneto/fan. Look at the keyway and see if the key has shifted some. Doesn't take but precious little to give you the symptom. Tom
mntbkr's Avatar
02-22-07, 03:30 PM   #3
Tom, You hit the nail on the head with your answer. Must of put too much pressure on the flywheel when I installed the starter clutch as the flywheel was about 180 degrees out and the key was sheared off. thanks much, Alan
puey61's Avatar
NY
02-22-07, 06:22 PM   #4
Actually, you did not properly torque the clutch (which is the flywheel nut) and likely were well under torque. By the way, the flywheel key is Briggs part number 222698S. And clutch torque will be 50 ft. lbs.
