Ariens Snowthrower
Old 02-28-07, 04:25 AM
Question Ariens Snowthrower
I need Help locating a carburetor overhaul kit for this unit. It has a Tecumseh HSK 600- 1670p engine in it. The local dealer has been less than helpful with the issue. From what I can see the numbers stamped on the carb are 1491 jcr and no other stampings. All of the web sites really dont give specific info for this engine except to replace it with a new carb.
Can anyone help?
Old 02-28-07, 08:37 AM
Tec carb
Your carb is 632608 The needle and seat kit 631021B comes with the bowl nut gasket & the bowl gasket may be all you would need. Carb kit would be the generic kit 632760B contains all of the common parts.
AJ
Old 02-28-07, 06:07 PM
Wink Ariens Snowthrower
Thanks for your Help
Old 03-02-07, 04:50 AM
puey61's Avatar
Actually, the 631021B does not come with a bowl gasket or jet gasket, this part number is only the inlet needle and seat. The 632760B, kit does come with these gaskets. Additionally, should you need them (and I recommend such), the new main jet/bowl nut is part number 632385 and the carburetor to engine mounting gaskets (two are required) are part number 510326A. So, I'd buy the 632760B, kit as well as the 632385, jet and the two, 510326A gaskets.
