2000 Yardman Wiring
Old 03-06-07, 09:55 AM
2000 Yardman Wiring
Hope Somone Can Help, I Have A 2000 Yard Man 18hp Tractor And I Need A Wiring Print When I Got It It Has Wires But Wiring Harness Going To Key Cut Off And Gone Need To Redo The Harness And Buy A Key Switch For It. Do Not Have Any Numbers No Lables On It.
Old 03-07-07, 12:24 AM
cheese's Avatar
With no model number, it's a crapshoot as far as finding the correct wiring diagram. You might do better by just buying a switch and wiring it according to the stamped letters on the switch connectors.
The typical switch letter abbreviations are:
B-battery
G-ground
M-magneto kill wire
S-solenoid
L-lights
Old 03-07-07, 06:35 AM
puey61's Avatar
The MTD factory may be able to help you. Try this phone number 1-800-800-7310 and have the following information ready for the technician: Year; Transmission type (hydro, trans-matic or autodrive); Engine: model, type and code; Frame style (if known, if not, just familiarize yourself before the phone call); And mower deck type (side-discharge, rear-discharge or mulching) as well as size cut.
