I have a snapper mower?
Gollina's Avatar
03-12-07, 03:22 AM   #1
So I bought a snapper mower off of craigslist. Its a great little mower. It needed a battery, a tire and little TLC. The guy before me at some point had repainted it red. The problem is that I can't find the serial number or model number anywhere on this thing to get an idea of what year or anything. It has the gas tank in the back left corner and I think its a 30". It has a 8hp Briggs and stratton. It really needs a new blade belt. The old one is cracked and is missing a few chunks. I can tell its not going to last much longer. If anyone can help I would greatly appreciate it.
Thanks
-nick
30yearTech's Avatar
TX
03-12-07, 05:37 PM   #2
Most of the older Snapper 30" riders used a Snapper Part Number 10749 (It's a 6 sided belt 68" long)
You can find owners manuals and parts lists at this web address.
http://www.snapper.com/#
The model number of the engine should be stamped into the starter shroud, look at the code number the first two digits should be the year the engine was manufactured (i.e. 74=1974). If the engine is the original one then chances are the mower was manufactured around the same time, give or take. Click on the publications link at the above address and you can enter the info you do know and narrow down a possibility of your units model number.
Good Luck
Gollina's Avatar
03-12-07, 09:59 PM   #3
Thanks for the info about the belt!!
I looked and by the spark plug it had.
Model Type Code
190702 1018 01 81061512
There was also a sticker that said serial number 30 9445
Do you think it could be a 1981? Here are acouple of pics.
<a href="http://www.putfile.com/pic.php?img=4971281" target="_blank"><img src="http://img1.putfile.com/thumb/3/7100495658.jpg" alt="Click to enlarge."></a>
<a href="http://www.putfile.com/pic.php?img=4971283" target="_blank"><img src="http://img1.putfile.com/thumb/3/7100495727.jpg" alt="Click to enlarge."></a>
<a href="http://www.putfile.com/pic.php?img=4971284" target="_blank"><img src="http://img1.putfile.com/thumb/3/710049579.jpg" alt="Click to enlarge."></a>
If these don't work go to
Gollina's Avatar
03-12-07, 10:02 PM   #4
evidently pics are not aloud. But aren't they worth a thousand words?
cheese's Avatar
GA
03-12-07, 10:42 PM   #5
The engine ID#s indicate that it is a 1981, and your description of the mower agrees. I think '81 is as close as you'll get with no frame/chassis numbers. Usually they're on a triangular shaped sticker on the frame near where the tube enters the rear frame under the seat.
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
Gollina's Avatar
03-13-07, 12:29 AM   #6
I found that sticker, but it had paint and years of grime on it. Thanks for all of your help!
30yearTech's Avatar
TX
03-13-07, 04:29 AM   #7
The engine in your picture looks like it may have been replaced. Originally I believe the engines on Snappers were painted white. That engine looks like a service replacement engine, I think your mower may be a few years older. As for parts most of the older models like this had few changes, try the Snapper site for a break down, or see if you can raise the numbers off the sticker you found on your unit.
Good Luck...
puey61's Avatar
NY
03-13-07, 12:29 PM   #8
I know my suggestion will be time consuming but without any numbers you don't have much choice. Go to this site and click on the "look up parts" link then click on Snapper from the drop down list and then the "product line" tab at the top of that page and then "rear engine riders" from that list. You will see several "series" units from which to choose and you can then look at each one and take notes for the parts you need and hopefully come up with the correct parts. http://www.jackssmallengines.net/partsf2.asp
Lindalou's Avatar
IL
07-09-08, 08:11 PM   #9
Thanks for the info on finding part numbers
Puey61, I have been hunting for at least 4 days trying to find information on my Snapper L14H41, no help at Snapper''s site. Thank you..
