Mantis Tiller
John24689's Avatar
03-17-07, 10:44 AM   #1
Mantis Tiller
Where can I find the model number on my Mantis Tiller?
I have a problem with gas leaking out of a gas line. It is not the gas filter inside the gas tank, but rather at the end of the tube that sticks out of the gas tank and has a filter on the end. This filter sticks up into a hole on the housing cover. Gas keeps dripping out of it. What is the problem and how can I correct it.
Thanks and have a great day.
John
30yearTech's Avatar
TX
03-17-07, 06:57 PM   #2
Should be on a sticker on the top of the blower housing, generally most of the 2-cycles are 7222e, the engine is manufactured by Echo for the 2-cycles and there should also be a sticker on the side of the crankcase near the carburetor and most likely is a SB/4 engine. The hose you are describing is probably the tank vent and that is a vent assembly on the end of the hose and not a filter. The Echo part number for the vent assembly is A356000030
