Fuel Line issue
Old 03-18-07, 10:25 AM
Fuel Line issue
I have a poulan 3300 with a hose loose that I think connects the carb to something maybe the cylinder. The question is how do I get to it without the use of a "monkey hand"? From the pull cord side? Thanks for any help.
David
Old 03-18-07, 02:48 PM
If you are talking about one of the little plastic fuel lines, they both run from the fuel tank and connect to the carb. One is a fuel supply line and the other one is a return. If either line is off the carb, you should be able to see the nipple it connects to and reconnect it.
Old 03-19-07, 05:57 AM
Azis
The return line to the tank should come from the primer bulb. If the lines are hard and unflexible, it would be a good idea to replace them.
Old 03-20-07, 12:12 PM
puey61's Avatar
I believe the hose you are referring to is the fuel pump pressure line. This hose will, in fact, go to the crankcase but, sorry, I can't say specifically how this needs to be routed nor, thence, how to perform the surgery. Stay tuned, perhaps someone else will.
