Briggs 28N707 (Sabre 1542HS lawn tractor)
cssna's Avatar
04-04-07, 02:41 PM   #1
I'm having a "running" issue with my B&S 15.5hp engine on a Sabre (JD) lawn tractor. Engine starts and runs fine, for about 8 minutes, then quits as if it has run out of fuel. Tank does have adaquate fuel. I have replaced the fuel filter (no difference experienced). I am able to restart, only in start (choke) setting, then dies again.
Any help would be greatly appreciated.
Thanks.
Azis's Avatar
04-04-07, 04:01 PM   #2
Azis
Have a look at this thread, sounds like the same issue.
http://forum.doityourself.com/showthread.php?t=300304
msidan's Avatar
NY
04-04-07, 04:18 PM   #3
Is the fuel cap venting? Take the cap off and see if it will start.
lanciault's Avatar
04-04-07, 05:19 PM   #4
b&S
fuel filter replaced - possible fuel celonoid or gummed up fuel line....clean or replace air filter...check spark plug and wires...spray choke cleaner in carburator...crank, crank, crank
cssna's Avatar
04-05-07, 08:52 AM   #5
Follow-up
Thanks, will try the suggestions and post results.
FYI:
Model: 28N707 (B&S)
Type: 1135-E1
Code: 000615ZD
cssna's Avatar
04-09-07, 09:06 PM   #6
Success!
Problem appears to have been the fuel cap vent blocked. Tested it by running it until engine began to cut out due to fuel starvation, then loosened the fuel cap and the engine ran normal. I did this 3 times in a row with same result. Time between each "venting" was approximately 5 minutes.
Thanks again for the help!
