Help!!!!
Old 04-09-07, 03:26 PM
Angry Help!!!!
i have an old turf trac lawn mower it wont start with out jumping acrost the silanoid its new and new fuses whats the problem??? help me !!!!!!!!!
Old 04-09-07, 04:41 PM
puey61's Avatar
So, the solenoid is new? If so and based on the fact you stated it was an "old" mower, you likely don't have safety switches that would come into play and would then have a faulty key switch or, at least, power wire to the solenoid from the key switch. Using a test light, check for 12 volt power to the small terminal on the solenoid (if you have two small terminals it will be the one that runs to the key switch) when you load the key to the start position.
Old 04-09-07, 05:59 PM
Make sure solenoid is grounded, there's not a broken wire from switch to solenoid, or key switch could be bad.
Trackbacks are On
Pingbacks are On
Refbacks are On
