noma lawn tractor 16.5 hp
Old 04-10-07, 08:52 PM
B
hi guys my noma has a tranny problem it starts out good when i first start it [cold] but after it gets warm it does not want to move on hills it. slips and moves slowly when cold it works great any ideas / any adjustments that can be done or sound like tranny is bad it is a peerless tranny too 16.5 hp tech motor bought around 97-98. is there any web sites to get any more info on this about where to get parts or info it all have no manual for it live in zip 14803 on flat ground slips some but move ok bothers most on hills
noone can get anything for it new or used thanks guys
Old 04-10-07, 11:40 PM
cheese's Avatar
Received 22 Votes on 19 Posts
Is noma the name on the hood? I don't recall for certain, but I don't think noma was still in business in 1997-98. What is the model#? Is the belt tight and in good shape?
Old 04-11-07, 07:44 AM
B
noma cont.
hi cheese, yes belt is only 4 months old not sure of the year will get a model number and get back to you yes it says noma on the hood i will doubl check the belt but it seems to be tight thanks guys bobster3
Old 04-11-07, 11:42 AM
C
Don't most riders have 2 drive belts ?
Old 04-11-07, 03:41 PM
v8driver's Avatar
Not on a murray/noma... one drive belt..
Do make sure its not worn... that is it seats in the pulleys groove well.
Grease could be clumped to the sides or low maybe.
Old 04-11-07, 08:46 PM
cheese's Avatar
Oh yeah, I forgot that Murray acquired Noma and used the name for a short time. They used the Dynamark name too a little while.
Is the tranny a hydro or standard?
Old 04-12-07, 07:44 PM
B
noma cont.
standard i do believe still waiting for my friend to give me the model number off it ? it is actually his but he has no pc to talk to people about this or get info about the noma thanks bobster3
Old 04-13-07, 04:48 PM
B
noma cont
hi guys, first tranny is a hydro not a standard ok here are some numbers i got model# g4316020
ser# s001307338462
code # 6078
ok tranny is a peerless and found a number on it 6205-p1 or pl
drive belt seems to be ok nice and tight and free of dirt and build up
how much tranny fuild and gear oil should there be in it also found that the rubber plugger like hose inside has a crack in it or slit in it thanks again guys bobster3
Old 04-13-07, 10:21 PM
cheese's Avatar
It sounds like it's either low on fluid or is going bad. There is no way to tell how much fluid is in it that I know of. I'd add 1/2 quart and see how it does. I'm not sure what type oil this takes. I'd be tempted to use hygard oil from John Deere (made for hydro trannys).
