Briggs & Stratton Model # 461707 Type 0145-E3
Old 04-12-07, 09:05 PM
I have a Craftsman lawn tractor with this engine, which is about 6 years old. The Sears repairman says that the engine is damanaged possibly because of an oil leak. He says there is no compression on one side. He suggested I junk it and buy a new tractor. Any advise on whether I can get this repaired? Is there any place where I can get a second hand engine? Thanks!
Old 04-12-07, 09:15 PM
cheese's Avatar
Received 22 Votes on 19 Posts
Hello Jacob!
It can be repaired if the block wasn't ruined when the problem occurred. Was it run low or out of oil? It could be a stuck valve, but is probably a broken connecting rod. Did it break the block that you can tell? You might get by with replacing just the rod and gaskets/seals. Only disassembly and inspection will tell.
