engine starts then dies...
Old 06-09-07, 03:12 PM
msidan's Avatar
Thumbs up
Success! (partly anyway)
One of the alternator wires was broken so I replaced the whole alternator an that works now...
When I replaced the alternator, I noticed the timing key was sheared. Replaced that and now this engine runs PERFECTLY SMOOTH! Didn't need that carb kit but oh well.
Another thing, after I washed this tractor, the key switch didn't work so I jumped it at the starter. I mowed a lawn for about 15 min. and when I shut it down, the key switch would start it . So it seems to only happen when the engine is cold. Any ideas?
Old 06-10-07, 10:57 PM
cheese's Avatar
Check the connections on the switch. The battery terminal on the switch tends to get rusty and lose connection.
A sheared flywheel key on a twin cylinder engine? That's almost unheard of unless someone has been into it before and didn't torque the flywheel nut tight enough.
  #43
Old 06-11-07, 06:04 AM
msidan's Avatar
It's possible the previous owner had the flywheel off. That plate under the flywheel that the shroud screws onto was missing all the screws which I think is what cut the alternator wire. The flywheel nut came off pretty easy too...
