Oil filter is stuck...knuckles are bleeding!!
Hi all,
I have a John Deere L115 with a B & S V-twin engine, purchased less than a year ago. Today, I tried to change the oil, and install a new oil filter. I cannot remove the oil filter. I tried a strap wrench. No go. I bought a fitted oil filter wrench that fits over the end of the filter. Using a big adjustable wrench, I started to twist. No go. In fact, I broke it, and actually twisted the metal of the filter, but it won't unscrew. It is the original factory installed filter.
I AM turning counter clockwise, by the way.
Does anyone have any ideas? This certainly isn't rocket science!
My bleeding knuckles and I will be grateful for any suggestions.
Thanks!
Thanks!
I agree...it's under warranty, and further attempts to remove the filter could potentially break something. The only other suggestion I can make is to try removing it with the engine good and hot. This may not be possible since the filter may be damaged too much to run the engine now. Warranty is probably the safest bet.
Thank you everyone for the suggestions. Today I called the dealer, who confirmed that others had had the same issue with that engine. He suggested a large Channel-Lock pliers. I went to the local hardware store and discovered that Channel-Lock makes a specially modified pliers just for removing oil filters! I bought a small one (they come in large and small), and with a LOT of muscle, the filter eventually came off. The new filter is now installed (PROPER tightness!), my hand is healing, and all is well.
