1972 Cub Cadet 129 Drive shaft pin shear
Old 04-17-07, 09:58 PM
jfh
jfh is offline
My 1972 Cub Cadet 129 would not go into motion after I stopped mowing for a moment.
I noticed the shaft connected at the rear of the engine where it fits into a collar just spins as I can see a pin sheared. This shaft seems to run to the rear end.
Is that a threaded bolt or what type of a pin woud it be.
I didn't want to try removal of the pin until I know.
Any help is appreciated.
Thanks
Joe
Old 04-17-07, 10:05 PM
cheese's Avatar
Received 20 Votes on 17 Posts
Hi Joe,
I'm not sure what type of pin is there, but I think I have one like yours at the shop. I'll try to remember to have a look at it tomorrow and see what's there. Probably a roll pin or a solid type shear pin.
Old 04-17-07, 10:16 PM
jfh
jfh is offline
Thanks Cheese for the response
I tried to continue mowing but the engine revved and no movement forward or backward.
When I opened the hood I saw a shiny spot on the shaft which is inside the collar on the rear of the engine. I reached in and was able to turn the shaft so I guessed that the pin sheared and if I can replace it, my problem may be solved.
I just didn't want to drive the remainder of the bolt or pin out until I know what is in the shaft.
I also wanted to know if it is a special pin that I will need to replace it.
I really thank you much for any help
Joe
Old 04-18-07, 03:17 AM
puey61's Avatar
I believe that this is a 1/4" X 1 1/2" roll (spring) pin.
Old 04-18-07, 01:11 PM
jfh
jfh is offline
Thanks to both of you: Cheese and Puey61
I purchased a solid pin to install and a spring roll pin for a spare.
I see the one that broke was a spring roll.
I installed the solid shaft pin and put a hose clamp around it so as not to have it fly out or..
I want to thank you guys for the help
Joe
Old 04-19-07, 04:32 AM
puey61's Avatar
You're welcome, JFH, and furthermore, if the solid pin is not a tapered pin then you should use the roll pin. A straight, solid pin is likely to have less than desireable tolerances and will likely have slop and then create more trouble for yourself.
