Kohler CV15S will not start
Old 04-19-07, 06:52 PM
Cool Kohler CV15S will not start
My Yardman with a Kohler engine started a ran a bit and stalled. My son did not change the gas from last year. I changed the fuel, fuel lines, filter and checked the air filter. It still will not start. Do I need to rebuild the carb?
Old 04-19-07, 10:01 PM
cheese's Avatar
Received 97 Votes on 90 Posts
Check for spark. If you have spark, drop the carburetor bowl and look inside. The float may just be stuck.
Old 04-21-07, 09:13 AM
Kohler will not start
What is the best way to check for a spark on this engine?
Old 04-21-07, 09:24 AM
Azis
An easy tester can be made with a set of battery cables and a spare spark plug.
Use only one lead of the battery cable, or similar test lead if you have one, connect one end on the spare plug hex or threaded portion, and the other end to ground on the engine or frame. Plug in the high tension lead and crank the engine while observing for spark.
Old 07-14-08, 02:20 PM
I
It may be your Fuel Solenoid is bad. Will it run if you give it a shot of gas or staring fluid? I've had one go bad on both a John Deere and a Craftsman.
To test for bad Solenoid:
Remove the Solenoid from the Carburetor and Replace it with a Bolt the Same Threads and Diameter 1/2 to 3/4' Long. Turn the High-Air-Mixture-Screw In to Seat. **SNUG DO NOT JAM** Then Reverse the High-Air-Mixture-Screw 1 1/2 Turns. Run the Engine and see if this Solenoid is Good.
Hope this helps.
Noel
Old 07-14-08, 07:48 PM
bontai Joe's Avatar
Start with simple stuff first. Check the inside of the carb to see if the flaot is stuck like Cheese said. Might be able to fix it with a spray of carb cleaner. If that don't work, then check for spark, If you have spark, then you might need to disassemble the carb and clean the individual parts and reassemble.
Old 07-24-08, 06:21 PM
D
I am having the same problem with my engine not starting but I checked and do not have a spark. What are the next steps?
Thanks
Old 07-24-08, 11:12 PM
cheese's Avatar
Start a new thread, post your mower brand, model, and engine info, and we'll go from there.
