Mower Gas Tank Leak
Old 04-28-07, 05:36 PM
Gen
Gen is offline
Mower Gas Tank Leak
My push mower has a leak on the top side of the gas tank where it bolts to the engine.
There is a crack, and the tank is aluminum. Ideally I would like to seal off the crack. What type of sealant could I try that is gasoline/oil resistant?
Thanks!
Old 04-28-07, 06:07 PM
hopkinsr2's Avatar
If you take you're tank to you're local rad repair shop, they should be able to weld the crack & seal the tank for you. I've had good luck with the guys around here & not a lot of $. Good Luck, Roger
Old 04-28-07, 06:36 PM
i had a cracked gas tank before, and used JB weld, the tank was plastic, itll work for aluminum also though.
Old 04-29-07, 04:56 AM
Gen
Gen is offline
Will silicone work? Is it gasoline resistant and bondable to aluminum?
Old 04-29-07, 06:15 AM
Smile
Go to your local wal-mart at automotive aisle there is a adhesive called
SEAL-ALL it says on the tube [email protected] resistant.
Jerry
Old 04-29-07, 12:16 PM
Gen
Gen is offline
Whatever I use will need to stay somewhat flexible. This particular mower rattles intensely.
Trackbacks are On
Pingbacks are On
Refbacks are On
