Mower won't re-start
thoppy1977's Avatar
04-30-07, 06:59 PM   #1
My mower won't restart after running anywhere from 20-40 minutes. Tried removing the gas cap, but that worked once.
Now I have to wait at least 30 minutes before it will restart.
Any ideas, thanks
cheese's Avatar
GA
04-30-07, 07:54 PM   #2
Any information? Maybe a bad coil, but we don't know what you have.
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
thoppy1977's Avatar
04-30-07, 08:41 PM   #3
Sorry I should have mentioned the mower is an Ariens w/ 6.5 Hp Tecumseh engine.
cheese's Avatar
GA
04-30-07, 09:10 PM   #4
Does it stall, or is it just hard to start after shutting it off when hot?
God bless!
thoppy1977's Avatar
05-01-07, 07:40 AM   #5
It won't start at all. It acts as though there is no spark when the engine is warm.
Azis's Avatar
05-01-07, 09:59 AM   #6
Azis
I think cheese was asking if it stops running on its own, Then will not restart...?
Unless it stalls and perhaps sputters or acts as though it ran out of gas, I would agree you may have a coil going bad.
Check for spark when it will not start.
Railbender's Avatar
05-01-07, 10:52 AM   #7
I had a similar problem and the crankshaft shear pin was partial sheared, also the magnet on the flywheel was severely rusted. After taking sand paper to the magnet and replacing the shear bin it ran fine. gary
Flyersfan72's Avatar
05-01-07, 07:37 PM   #8
similar problem
Hi. I have a similar problem to the one thoppy1977 is having so I thought I should post my message here.
I have a 4hp B&S sitting on top of a 22" Murray walk-behind. It will run for about 10 minutes of so and then just stalls. I can start it again after a few pulls but it will only run for 30 seconds tops then stalls again. When it is running it runs good but "sputters" every couple seconds - for lack of a better word. Like it's "sputtering" but just for a brief amount of time then it idles normally. It will do this even if it's sitting still and I'm not pushing it. When I first start it, it runs beautifully. Then within maybe 10-15 seconds the sputtering starts.
I've replaced the plug and the air filter. I noticed a few specs of dirt in the bottom of the tank so I took the tank off and drained the gas and washed out the dirt as best as I could. Seems almost as though it's overheating? I didn't notice any debris around the engine.
Any suggestions, please?
cheese's Avatar
GA
05-01-07, 09:06 PM   #9
Thoppy1977...have you checked to see if it has spark?
Flyersfan72...is the air filter caked up with junk? New spark plug? If you have a clean filter and new plug, I'd suggest replacing the carburetor diaphragm.
God bless!
thoppy1977's Avatar
05-02-07, 08:20 PM   #10
I'll will check for no spark the next time I mow and this happens. Mower is at my parents house.
