Toro Trimmer
Old 05-01-07, 10:42 AM
Smile Toro Trimmer
Does anyone have general info on a Toro TC700 gas lawn trimmer (SRM-200AET). Year, fuel mixture etc. Thank you, gary
Old 05-01-07, 12:05 PM
puey61's Avatar
You should find a sticker with an actual model and serial numbers, most likely on the shaft of the trimmer. Note these numbers and go to this link and type them in where required and you will have all the information you need. https://homeownersolutions.toro.com/portal/server.pt?space=CommunityPage&cached=true&parentname=CommunityPage&parentid=2&in_hi_userid=19461&control=SetCommunity&CommunityID=214&PageID=0
Old 05-01-07, 03:54 PM
30yearTech's Avatar
Smile Tc 700
Straight shaft 17" cut 21.2cc trimmer Toro model number 51607
Manufactured for Toro by Kioritz Corporation (Echo) 1982-1984
Echo Model number SRM-200AE
Suggested fuel mix ratio 32:1
Old 05-02-07, 11:43 AM
Toro trimmer
Thank you for the info. What a great site. gary
Old 03-25-08, 10:25 AM
Know what I can use for an ignition coil for this? The originals are obsolete
Old 03-26-08, 07:10 PM
puey61's Avatar
Bruce, is yours this exact same model number? If so, then check with an Echo dealer or one of several aftermarket suppliers...Stens, Rotary, Oregon, etc.
Old 03-28-08, 01:53 AM
The Echo model was an SRM-200AE. My Toro is an
SRM-200AET. Are they one and the same? Can they use the same ignition coil? Someone said that it also went under the Lawn-Boy name.
Old 03-28-08, 03:19 AM
puey61's Avatar
Not absolutely certain but confidently so that they are the same unit.
Old 04-01-08, 02:00 AM
As far as I can determine the current 21.2 cc engine echo uses now is basically the same engine they used then. Shouldn't they be able to use the same coil? What determines the coil they use?
Old 04-01-08, 06:18 AM
puey61's Avatar
Radius, bolt pattern, power, demand, etc. In other words, could be many variables.
