Starter gear on flywheel
Old 05-08-07, 09:48 AM
I pulled off a flywheel that I needed to replace the starter gear on it and noticed it had four rivets holding it on the flywheel. Do I just grind or cut them off and replace them with bolts or will the new gear come with rivets? I always just assumed the gear was bolted on. It is on a B&S m-28A707, t-0122-02, c-961213ZA...10HP.
Old 05-08-07, 02:28 PM
T
I've looked at your IPL and that engine is very similar to mine. The bracket (item 801) should just have two torx bolts that hold it on to the block.
Unless I'm missing something or your's is customized/modified, you shouldn't have to mess with rivets at all.
Hope that helps.
Old 05-08-07, 03:30 PM
ttow,
I'm not talking about the starter gear on the starter shaft, its the gear (fiber or nylon) on the bottom side of the flywheel. It's held in place by four rivets.
Old 05-08-07, 03:49 PM
T
Sorry, I should have known it was ring gear from context.
I've never had to replace one...but here is a link to an active ebay auction with a picture of it for reference. Is that the right part?
http://cgi.ebay.com/NEW-FLYWHEEL-RING-GEAR-AND-HARDWARE-FOR-BRIGGS_W0QQitemZ200106169176QQihZ010QQcategoryZ50371QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Looks like it comes with 4 bolts to replace the rivets?
Old 05-09-07, 12:17 AM
cheese's Avatar
Received 55 Votes on 50 Posts
You got it...the new ring gear comes with new screws and nuts. I just drill the heads off the rivets and drive them out with a punch.
