mower deck belt adjustment??
Old 05-15-07, 07:27 AM
I just got a 1970 cub cadet 106 w/42" mower deck. It keeps throwing the belt off. I have replaced the belt with a longer one (82) (I still have to remove the adjusting bolt completely it get the belt on). Any suggestions?
Old 01-05-08, 05:07 AM
throwing belt ,you might check the pulley bearings on each blade! Rick
:mask: i
you might check the bearing rollers that each blade has,,,this could very well throw the belt
Old 01-06-08, 10:56 PM
cheese's Avatar
Id first suspect the routing of the belt...make sure you're routing it right. Also check for bad bearings in all pieces, and look for worn or bent pulleys.
