Throttle linkage for a Craftsman “Eagar-1”
Old 05-16-07, 12:07 AM
I need a diagram or a picture of the throttle linkage for a Craftsman “Eagar-1” push lawnmower.
Model # 917 386061
Engine Model# 143965004
Carburator # 51-0-150
15
Any help is much appreciated.
Old 05-16-07, 02:02 AM
puey61's Avatar
Stay tuned for Azis to read your post, he has a link to Tecumseh service manuals that should help you out.
Old 05-16-07, 06:56 AM
Azis
Here is the manual url Puey mentioned http://www.cpdonline.com/692509.pdf
You may also find a better diagram or part breakdown on the sears site.
http://www3.sears.com/
Use your model # to find a diagram for your mower, find the part number for the carburetor, then do another search using that part number as the model #. If there is more detail available it should return results.
Old 05-16-07, 09:35 PM
the sears site only broke things down to the engine, but the Tecumseh service manual looks to be more helpful, plenty of diagrams and I believe I seen my linkage illustrated.
Thanks a bunch Azis
Old 08-26-13, 08:46 PM
The fixed rod with the spring on the (front) end goes from the anchor in front of the carb (usually a bendable tab) to the LOWER hole of the 2 hole lever off the mower body toward the rear of the carb. The S shaped rigid linkage hooks from the UPPER hole of the lever to one of the holes on the bellcrank of the carb usually inboard of the shaft, ie. 2nd hole.
Old 08-27-13, 07:46 AM
Received 2 Votes on 2 Posts
Steven, this thread is 6 years old so the problem has probably been solved. Have a good one. Geo
